will5572
Message 1 of 19
unable to connect to war thunder.
hi there i play an online game called war thunder and for the past week or so i have been unable to connect to the eu server. i ran a tracert and it came back with a problem, id appreciate any help with this please 🙂
Tracing route to host01lw-nl.warthunder.com [37.48.71.129]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms BTHomeHub.home [192.168.1.254]
2 44 ms 17 ms 17 ms 217.32.142.111
3 30 ms 22 ms 18 ms 217.32.142.158
4 24 ms 24 ms 23 ms 212.140.206.18
5 24 ms 24 ms 24 ms 213.120.162.65
6 24 ms 25 ms 24 ms 31.55.165.107
7 31 ms 24 ms 23 ms acc1-10GigE-9-2-0.mr.21cn-ipp.bt.net [109.159.250.100]
8 33 ms 31 ms 31 ms 109.159.255.145
9 34 ms 34 ms 36 ms peer3-te0-2-0-1.telehouse.ukcore.bt.net [109.159.254.144]
10 * * * Request timed out.
11 39 ms 39 ms 39 ms 62.212.80.151
12 38 ms 38 ms 37 ms po1001.ngn-ams1-cs2.leaseweb.net [5.79.79.241]
13 46 ms 43 ms 43 ms 37.48.71.129
18 REPLIES 18
Distinguished Guru
Message 2 of 19
Re: unable to connect to war thunder.
That's not a problem as you get a reply from the destination.
If not, I'll try again 🙂
will5572
Message 3 of 19
hi Ray, thanks for your reply. i thought the same but they have assured me the problem is from my ISP so i dont really know how to proceed, i have put quite alot of money into it over the last couple of years so id like to get it sorted, do you have any ideas?
Distinguished Guru
Message 4 of 19
You are playing over a wired ethernet connection. aren't you?
will5572
Message 5 of 19
yeah mate 🙂
will5572
Message 6 of 19
hi ray not sure if you can see this. the game developers are insisting the tracert means there is a problem with my isp so they are refusing to help me any further. what should i do now?
Distinguished Guru
Message 7 of 19
They may be right that the problem is with your ISP, but the traceroute does not show that. They may be wrong as well, and the problem is their end.
will5572
Message 8 of 19
thanks again for your reply! yeah the thing is ive played that game since closed beta testing and nothing has changed at my end. my account is still running and i havent been able to access it for 2 weeks now. doing my head in!!!
Distinguished Guru
Message 9 of 19
Have you tried connecting another way to see if their server is ok?
For example, BT Wifi, mobile phone 3G/4G, VPN ?
will5572
Message 10 of 19
just ran another trace.
1 <1 ms <1 ms <1 ms 192.168.1.254
2 17 ms 18 ms 17 ms 217.32.142.111
3 18 ms 18 ms 17 ms 217.32.142.158
4 24 ms 24 ms 24 ms 212.140.206.18
6 25 ms 24 ms 24 ms 31.55.165.107
7 24 ms 24 ms 23 ms acc1-10GigE-9-2-0.mr.21cn-ipp.bt.net [109.159.250.100]
9 34 ms 35 ms 35 ms peer3-te0-2-0-1.telehouse.ukcore.bt.net [109.159.254.144]
11 41 ms 41 ms 41 ms 62.212.80.151
12 38 ms 38 ms 40 ms po1001.ngn-ams1-cs2.leaseweb.net [5.79.79.241]
13 46 ms 46 ms 48 ms 37.48.71.129
Trace complete.
keeps timing out after telehouse number 9. mmm what does that mean exactly lol?
