Message 1 of 10
unable to order Broadband
For the last 2 days I've been trying to order Full Fibre Broadband, yet whenever I try, I just get "We're sorry, we can't process your order at the moment". When I click on the order tracking link provided, I just get an error message.
The name on the account was changed on  8th November by the Bereavement Team following the death of the account holder. I was told the account would update within 24 hours, but it hasn't.
I haven't placed any orders.
9 REPLIES 9
Message 2 of 10
Re: unable to order Broadband
are you the account holder now or what happened when BT notified of account holder's death?
Message 3 of 10
I have Power of Attorney for the new account holder. That power has been registered with BT
Message 4 of 10
can you access MYBT and check if the account holder change has completed as BT can only process 1 order at a time so if that is still not completed or there is another outstanding order then you will not be able to place another order
Message 5 of 10
I can see on MyBT->Your details->Profile->Your Personal Details still has the old name.
I long should I wait for it to be changed before chasing up?
Message 6 of 10
I would contact CS now 03301234150
or try message now to billing    https://www.bt.com/help/contact-bt/account-and-billing/broadband
Message 7 of 10
I can report that
(1) the facility to message the billing people doesn't work - you just get a scripted response from the chat bot, and I was unable to enter any further information as the reply field was greyed out
(2) the order tracker doesn't work
I called CS and they're saying the transfer will happen "by the end of tomorrow", so 5 days instead of the original quote of 24 hours. Pity I had to waste time and money phoning up to find that out.
Message 8 of 10
Calls to BT are free
Message 9 of 10
@DodgyGeezer
Just tried my link and it works fine and selecting message now brings up window to type your question  maybe try diffent browser
Message 10 of 10
calls to 0330 numbers aren't free on Giff Gaff mobiles
