baker1607
Message 1 of 8
upgraded from BT infinity one to infinity two
Hello this is my first time posting. All in short I received a offer from BT last week to upgrade to infinity two my activation date was yesterday and still I have not seen an increase in speed except for 10 minutes past twelve when I went from 50 down and 10 up to 63 down and 18 up then my speed went back to infinity one any help on this would be apriciated thank you
Tags (1)
7 REPLIES 7
Message 2 of 8
Re: upgraded from BT infinity one to infinity two
Welcome to this user forum.
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Then, if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post lines 1-12
Or post the information from the smart hub, using this link.
http://192.168.1.254/0000012803/gui/#/technicalLog/information
baker1607
Message 3 of 8
baker1607
Message 4 of 8
Screenshot_2017-03-15-11-52-01.pngScreenshot_2017-03-15-11-52-12.pngScreenshot_2017-03-15-11-52-24.pngScreenshot_2017-03-15-11-52-28.png
Message 5 of 8
If that's now, then you're back on Infinity 1.
baker1607
Message 6 of 8
baker1607
Message 7 of 8
It all seems to have gone through but no difference in speed I guess I'm just going to have to ring them
Moderator
Moderator
Message 8 of 8
Hi @baker1607 and thanks for posting.
Can you try the speed tester including the further diagnostics and post the results?
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
