Message 11 of 18
Re: upload speed
Hi. the line test is quiet no noise at all  the hub is connected to openreach  NTE5C socket as it always has been
Message 12 of 18
Re: upload speed
Hmm, well there's definitely a fault. Can you try connecting the Hub to the test socket? It's the socket behind the faceplate, which can be removed very easily. Then, paste the stats again.
Message 13 of 18
Re: upload speed
Hi , Im not sure if I can as  the socket is downstairs  and  is connected to the hub which is upstairs by a Cat5 cable . isnt the test socket a phone type plug rj11
Recognised Expert
Message 14 of 18
Re: upload speed
Yes.  You need to use a filter.
Message 15 of 18
Re: upload speed
im not technical but doesnt  the openreach socket  seperate phone line and broadband and do away with the need of a filter
Message 16 of 18
Re: upload speed
No, the test socket is just a phone (RJ-11) socket, so you need to use a filter.
Message 17 of 18
Re: upload speed
I will try it tomorrow  and post result. thank you
Message 18 of 18
Re: upload speed
Didnt get around to test socket try as could not find a filter but checked speed this morning and its back to 38.18 mbs download  & 6.38mbs upload . So problem seems to have cleared must have been a BT fault thank you  to all for suggestions & help Smiley Happy
