Message 1 of 7
vdsl2 How many errors is acceptable?
I am on vdsl connection. I would like to know how many errors is acceptable?
Its been 5 days of uptime, I have on the upstream 508 errors. Downstream 0 errors.
Is this in an acceptable range?
6 REPLIES 6
Message 2 of 7
Re: vdsl2 How many errors is acceptable?
How are you determining the errors, are they FEC errors, CRC errors or other error count?
Message 3 of 7
Message 4 of 7
I posted you a picture can you see it?
Message 5 of 7
I assume that is from a Tp Link device, not entirely sure what it is measuring, but I wouldn't have thought 518 errors in 5 days is excessive whatever it is reporting.
Message 6 of 7
we have a water leak outside our house that needs fixing its probably creating noise on the line
Message 7 of 7
if there was a problem with your line your connection speed would not be almost at attainable nor would your noise margin be at 2.9db showing G.INP is active on your line
