masychef
Message 1 of 5
what does it mean when dsl checker sais FTTP available and then at the bottom FTTP not available?
4 REPLIES 4
Message 2 of 5
Re: what does it mean when dsl checker sais FTTP available and then at the bottom FTTP not available
FTTP on demand is not the same as FTTP FTTP on demand is more for business due to the costs involved
masychef
Message 3 of 5
i have no need for fttp 30mbps is super fast to me ultrafast. was just curious ah so its mostly for buisinesses, thanks
Message 4 of 5
The checker doesn't say FTTP is available, it says FTTP on demand is available.
Moderator
Moderator
Message 5 of 5
Hi @masychef welcome to the community and thanks for posting. The FTTP on demand service is a bespoke fibre installation for your property and requires the customer to pay for a survey so the job can be costed then the full expense of running the fibre from the exchange to your home are charged if you decide to proceed. The installation costs are usually in the thousands or 10s of thousands and the rental can also be quite inhibiting for normal residential customers.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
