tonyburton
Message 1 of 16
wrong post code Openreach
Hi
We have tried to upgrade to fibre broadband but rejected since March.
After a lengthy communication with BT and Openreach, we were told we cannot get fibre broadband from BT as the quota for BT was full.  In the process of application for fibre broadband which revealed that our postcode was incorrect on Openreach database and therefore we cannot get fibre from anyone as it stands.  We know that fibre broadband is available in our area, as our neighbours of either side of us have it.
Following the advice that only the current provider can instruct Openreach to correct data on their system, we contacted BT and raised a complaint.  We had three lengthy online chats in June but despite promises of help the system had not been corrected.  We then spoke on telephone, quoting our open complaint.  This resulted in the correction of wrong post code on BT's database, and were assured the Openreach database would be sorted by 16 Jul.  However, when we tried the upgrade application, we got the following message; 'Sorry - your telephone number and your postcode do not match'.
It appears that despite our many contacts with BT, we still cannot to get any result.  Can anybody help?
15 REPLIES 15
Dean007
Recognised Expert
Message 2 of 16
Re: wrong post code Openreach
Hi @tonyburton
Is your address correct on the Royal Mail address checker ?
tonyburton
Message 3 of 16
Yes, it is only BT/ Openreach that has it wrong
Dean007
Recognised Expert
Message 4 of 16
@tonyburton
This is something the moderation team need to help with. I’ll ask them to pop by and have a chat but they are fairly busy so keep checking back.
Moderator
Moderator
Message 5 of 16
Hi @tonyburton
Welcome to the Community and thanks for your post!
Sorry for the problems you're having upgrading to fibre broadband due to the mix up with your postcode.  As your services are with BT we can help you get it updated from here.
Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.  When you complete the form, please include the correct address format as listed with >> Royal Mail <<
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
Moderator
Moderator
Message 6 of 16
Hi @tonyburton thanks for sending over your details. I've contacted Openreach to get your address records corrected. This normally takes 7-10 days but as soon as I have an update I'll drop back and update you.
Cheers
John
Community ModeratorJohnC
Kudos”Kudos”
Moderator
Moderator
Message 7 of 16
Hi @tonyburton Openreach have got back to me and confirmed that your address records are now corrected.
Cheers
John
Kudos”Kudos”
tonyburton
Message 8 of 16
The availability checkers on Openreach website says it's available and advises us to check with the providers, as the exchange is Fibre enabled. We've re-tried BT and other providers to see if it works. And unfortunately, the applications were all rejected including BT. So, we're completely stcuk again. Can you help on this one?
Message 9 of 16
enter your phone number and post results  remember delete number    https://www.btwholesale.com/includes/adsl/main.html
tonyburton
Message 10 of 16
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 14 -- 8 to 18.5 Available -- --
WBC ADSL 2+ Annex M Up to 14 Up to 1 8 to 18.5 Available -- --
ADSL Max Up to 7 -- 6 to 8 Available -- --
WBC Fixed Rate 2 -- -- Available -- --
Other Offerings
Availability Date
ADSL Multicast -- -- -- Available -- --
Premise environment
Status
Bridge Tap U
VRI N
NTEFaceplate N
Last Test Date 18-07-2018
