ejwjohn
Newbie
Message 21 of 24
Re: Alternatives to the Home Hub 3
Hi,
Setup CD does not work on MAC OSX and i do not think it covers BT infinifty set up
John
Distinguished Guru
Message 22 of 24
It seems to suggest it configures itself anyway.
http://en-uk-support.belkin.com/app/answers/detail/a_id/7310
Router Setup - F7K and F9K Models Without CD
Follow these steps to install your F7K or F9K model router. You will need the following:
  • Your Belkin router
  • A modem (usually provided by your Internet provider)
  • A computer
1. Unplug the Power to your modem.
2. Connect the Ethernet Cord, which comes attached to your router, to your modem's Internet Port.
3. Plug in the Modem's Power Cord.
4. Plug in the Router's Power Cord.
5. Connect the second provided Ethernet Cord to one of the router's four LAN Ports and then to your computer.
If not, I'll try again Smiley Happy
ejwjohn
Newbie
Message 23 of 24
Ok,
I resetthe unti to Factory default settings, performed the steps you indicated. and it failed to connect.
Then changed the method to PPOE and put the bthomehub@btbroadband.com in as the user and i had to put bt as the password, it would not accept spaces.
And it worked!!
Thank You very much for your help.
John
Distinguished Guru
Message 24 of 24
Sounds like the factory reset did the trick Smiley Happy
