jgar1
Message 1 of 22
BT Infinity Checker
Hi. I'm really confused. I have been considdering Infinity 2 for the last month as the checker has stated available now and download speed of 59Mb. This has also been the case with all the other providers Plus net, Sky etc. I checked again this morning and again it was available. I was going to sign up tonight and suddenly the checker now says not available. This is now the same on all the other providers I have checked my exchange on the openreach site and it says it is enabled. Any advise please??
James.
Message 2 of 22
Re: BT Infinity Checker
The most likely reason is there is a problem with the activation of your cabinet I am afraid all you can do is wait hopefully not to long
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
jgar1
Message 3 of 22
Thanks. Does seem a little strange. The FTTC check and SamKnows checker still say that my telephone number and postcode are enabled.
Guru
Message 4 of 22
The other possibility is that all the slots on the cabinet have now been allocated.
jgar1
Message 5 of 22
Does that mean I may not be able to get fibre for some time?
Guru
Message 6 of 22
If the slots are all allocated it is likely to be quite a time. If it is an activation problem (which I think is more likely as John suggested) then it might not be. Pretty vague, sorry, and I don't know where you can go for better information.
jgar1
Message 7 of 22
Thanks guys. Was getting over excited with the thought of a faster speed, back to my 180kb downloads then Smiley Sad
Guru
Message 8 of 22
They would just add another box, what they did to mine.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
Distinguished Expert
Message 9 of 22
Check your phone number here http://www.dslchecker.bt.com/adsl/ADSLChecker.TelephoneNumberOutput
when it says you can get fttc then you can order
Message 10 of 22
very unusual to install a second cabinet
Try a Search
