Do you mean
Re: BT throttling P2P (Big time)
Seems a bit drastic....and possibly illegal as you entered into a contract with BT.
no point in explaining to some people if you break a contract then you have to pay all that will happen is debt collectors will become involved with extra costs
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Well you will see the bailiffs or court for you. Unlucky
Just sign up for a VPN and get almost full speed torrents all the time and stop complaining.
Expert
Another option is my D-link NAS enclosure have a p2p clinet in it so you acts as a seedbox, and that only costs £40 plus the cost of a hard drive.
Or find another way of getting content.
Does this also affect Steam downloads? Because iirc that was peer-to-peer and also Skype.
No, Steam is not P2P
Expert
Steam is direct off their servers, I can max out their downloads 24/7 at 4.5 MB/sec
Yes, in the green frog times though they actually denied they werer doing it. Point blank denials. The CS person i spoke to showing them absolute and utter proof that throttling was happening on specific ports said i didnt understand and BT wasnt throttling.
That was about ten years ago. I have not had BT as a ISP since then. I dont like been lied to and then insulted. Plenty of other businesses out there want my custom.
