Do you mean
Expert
BTCENTRALPLUS, IP Address?.
Hi,
Just wanted some answers really. In the IP address 0.00.BtCentralPLus0.00, for example, how many IP addresses over the UK would that cover? If so where abouts does BTCENTRALPLUS cover, which area?. I really do not know alot about it and would like some kind information on it. Does it just cover my IP address or lots of others?.
Thanks.
Please click on white star to the left and say thanks if I have helped you at all!. Smiley Happy Thank you. Some handy links Copy & Paste:-
http://bthomehub.home/
http://netalyzr.icsi.berkeley.edu/index.html
http://diagnostics.bt.com/login/?workflow=Speed
Distinguished Expert
Re: BTCENTRALPLUS, IP Address?.
bt central plus is the aggregate link from the bt bras to the internet
Expert
Yeah, but what does it mean?. Is it in everyones IP Address or not or just me?. Please let me know some info?.
Guru
Hi MBR123,
I'm on Adsl BT Broadband and my IP Address is 109.157.***.*** but it is also know to BT as host109-157-***-***.range109-157.btcentralplus.com.
cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Guru
[ Edited ]
You will never found out the amount of IP's BT use as this changes all the time, a more realistic approach would be to find out how many blocks(range) that BT use.
BTCENTRALHOST is used on every block to my knowledge.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
Expert
[ Edited ]
Thats what I meant, mine is host, something, btcentralplus. So its not just related to my IP address, but everyone else with BT, so that could be millions of customers, write?.
Is btcentralplus just located in the UK or around the world, cause BT surely is not just UK related, is it?.
all uk customers connected via bt central plus will have a reverse dns entry showing their ip address along with btcentralplus.com
Expert
[ Edited ]
Another question about it, for example, if that IP address had btcentralplus in the title could they relate that to there address even if millions of customers had btcetralplus in there addresss as well?. I mean say Jo Bloggs had, 1234btcentralplus1234 and his next door neighbour had say 4321btcentralpus4321, could they still relate the Jo Bloggs address even if the site only new about the btcentralplus part of the address? or would they not know for sure who is who by just knowing the btcentralplus part,even when Jo Bloggs is 1234 and next door neighbour is 4321?. Anyone.
Guru
Of course they know where each IP goes.
they could ask bt and bt could tell them who was using the ip address at the time
