vofsanity2
Recognised Expert
Message 1 of 15
BTW Performance Tester
I have been trying this off and on during the day and on the Further Diagnostics button getting
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
Am I alone in getting this problem ?
Message 2 of 15
Re: BTW Performance Tester
have you the latest version of Flash-player installed
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Distinguished Guru
Message 3 of 15
Working fine here - but I'm not on Infinity.
-+-No longer a forum member-+-
Starman
Message 4 of 15
I've had this happen to me a couple of times but when I again try later on it then works fine. So i suspect maybe its a load related issue.
BT Infinity (EASTF) 58.93/15.94 Mbps [IP Profile: 60.8/20 Mbps] using Openreach Modem & Billion BiPAC 7800N
vofsanity2
Recognised Expert
Message 5 of 15
Thanks for your replies gentlemen.
I am using the latest flash player according to the Adobe web page.
I have also checked it works on an ADSL line.
I have tried more than one machine and it still fails on my FTTC line.
I have tried at several times from 09.00 to 24.00.
I have now raised a fault report since no one else seems to be having the problem so it may be peculiar to my account.
It last work successfully for me on 21/02/2013.
Starman
Message 6 of 15
Funny this vof, I had exactly the same issue about a year ago and it didn't work successfully for about a month I even raised the issue with the mods and they basically informed me it was completely out of their [BT Retail] hands. BT Wholesale issue.
Guru
Message 7 of 15
There was a few of us last year who posted here where we couldn't see our IP profiles or any information for about 2 months. Never got an answer and I'm currently still chasing it up to get one.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
vofsanity2
Recognised Expert
Message 8 of 15
Starman,
Thanks for the info.  It may be a BTW issue but BT retail need to get it fixed.
Ryant704,
Yes I am looking for my profile information also. Last years problem seemed to be Java related that was why I started using the BTW version.  Also the BE option does not work because it says BTW refuses to provide the information.
I will see how my fault report progresses but if it is not successful I have plan B ready. Watch this thread !
Guru
Message 9 of 15
vofsanity2 wrote:
Starman,
Ryant704,
Correct, we couldn't also use the bRAS checker. I will find the old forum thread and post it here.
http://community.bt.com/t5/BT-Infinity/Speedtester-bt-com-not-working/td-p/698218
vofsanity2
Recognised Expert
Message 10 of 15
Tester is still failing as posted above. Plan B does not seem to be working although still being pursued. Started Plan C with Plan D in the feasibility stage.
I noticed that the last page of the BTW tester has the following error:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; GTB7.4; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; .NET4.0C; .NET4.0E; BOIE8;ENUS)
Timestamp: Wed, 13 Mar 2013 15:02:51 UTC
Message: Object required
Line: 98
Char: 1
Code: 0
URI: http://speedtest.btwholesale.com/PerformanceTesterWS/check_test_completed.do
