Do you mean
Accepted Solution
Can i get FTTP ?
Re: Can i get FTTP ?
Yes, if you want to pay.
FTTP on demand cost
Prices for 2018
Forumhelp (Private website) Lots of additional information and help.
You will need to be connected to your home BT Broadband connection to view it, or any links to it that I post on this forum.
FTTPoD is not the same as FTTP
cost of FTTPoD https://www.openreach.co.uk/orpg/home/products/pricing/loadProductPriceDetails.do?data=0WyIM7tTGGguc...
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
Theres a lot of info on that page, but to summarise, the minimum per month is £92 right ?
What is the difference ?
You also have survey fees and installation costs as per the distance they have to lay the fibre.
FTTP on Demand is a bespoke fibre solution for your premises. It is primarily aimed at businesses.
FTTP is the residential Fibre to the Premises and is usually only available if there is no FTTC Fibre to the Cabinet available due to distance from the cabinet.
You are able to get FTTC so you will not be offered FTTP.
Great, thanks Smiley Happy
