Do you mean
How fast should I be able to download?
I have had BT infinity for 2-3 months now, and I never seem to get a download speed of more than 4 megs a second Smiley Sad
It can start at 6 every once in a while, last about 10 seconds and then quickly run down to 3-4 megs and sit there until the d/l is finished.
According to the BT speedtest my internet is 78mbps down and 20mbps up.
Anyone able to through the numbers I should be getting in my direction?
Many thanks
Re: How fast should I be able to download?
file transfer speeds will vary from web site to web site dependant on there sever speeds and the amount of people downloading from them
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
ATM I cannot even stream a video, yet I can stream is perfectly on my mobile phone. Havn't been very impressed with the servive from BT so far, I requested a call back from an engineer about poor speeds most of the time, and nothing Smiley Sad this was 2-3 weeks ago.
Guru
Are you using wired or wireless connection?
Wired
Distinguished Expert
you should see 9 megabytes per second
