Do you mean
Port Forward help using BT Infinity & HH3
This is my first post as a newbie to BT Infinity Broadband, so be gentle with me.
I have signed up for BT Infinity which was connected and installed on Friday 25/2/2011
I'm trying to port forward to an internal webserver that I have setup.
Using the website "What's my IP Address", it reports my IP address as 81.151.114.xxx
On the Home Hub 3 i have setup a new rule to point TCP port 8080 to my internal PC 172.16.xxx.xxx.
In the IE8 address bar i type http://81.151.114.xxx:8080 but i get an error "Internet Explorer cannot display the webpage"
I can view the webpages from a local laptop by typing in the address bar http://172.16.xxx.xxx:8080.
Can anyone help to solve this.
Many thanks.
MrP
Re: Port Forward help using BT Infinity & HH3
I thought I'd read somewhere (on these forums) about the issue of trying to access your network via your external IP address when you are currently within your local network? I'm sure the solution was fairly straight forward, but I can't just find it at the mo.
[ Edited ]
Does this page tell you the port is open? http://www.canyouseeme.org/
Also have you allowed the port through your own Windows firewall?
Forumhelp (Private website) Lots of additional information and help.
You will need to be connected to your home BT Broadband connection to view it, or any links to it that I post on this forum.
Yes the port is open
Success: I can see your service on 81.151.114.xxx on port (8080)
Your ISP is not blocking port 8080
You could try using a different web like Firefox, just in case Internet Explorer is misbehaving, as it often does.
Otherwise you will have to ask someone outside of your network to test it for you. If you cannot find anyone, then I can help if you wish to send me a PM.
SUCCESS, just tried it from a PC outside of my network and the webserver works a treat Smiley Very Happy thank you Keith.
I will mark as solved once a solution can be found to the question below
@MrP
[quote]I thought I'd read somewhere (on these forums) about the issue of trying to access your network via your external IP address when you are currently within your local network? I'm sure the solution was fairly straight forward, but I can't just find it at the mo.[/quote]
I interested in this solution if anyone can assist.
Many thanks
After searching the internet into this problem I believe I have found a website which details a problem with the BT home hub 3 (can't comment on the HH 1 or 2 as I have never owned one).
Basically the HH does not allow NAT redirections which causes this problem more information in the link below
http://www.dyndns.com/support/kb/loopback_connections.html
How can we initiate a firmware update be installed to allow this loopback traffic, can a Moderator help?
Could the above solution also be linked to the problem I am having (see link below)?
http://community.bt.com/t5/BB-in-Home/HH3-stops-Windows-Remote-Assistance-amp-Remote-Access-to-Home/...
Stab in the dark: did you try disabling extended UPnP security?
Not sure who that question was for, so i disabled it anyway but still no access from the internal network
