Do you mean
Newbie
Really slow bt infinity
It's supposed to be 65 Mbps (HA FAT CHANCE) and its at 6 Mbps
Really bt
I am going to switch to virgin media soon, I have had enough of your cr*p.
It takes hours to get to customer service then all they say is (have you tried turning your modem off and on) NO I DIDN'T THINK OF THAT AFTER THE 17 TIMES YOU HAVE SAID THAT TO ME
Seriously bt make faster Internet or give what you say you sell.
Or I will get everyone I know to buy virgin media and sky
Distinguished Guru
Re: Really slow bt infinity
[ Edited ]
If not, I'll try again Smiley Happy
Guru
Hi
Can you do a test here, make sure you are doing the test with ethernet cable direct to the HomeHub. Click on "Beging test" to start, once the first test has completed and it dispalys some speeds you will see "Further Diagnostics". Go and click on "Further Diagnostics", you will then need to enter your telephone number in the Fibre to the cabinet box. Then copy and paste the results it gives.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
Newbie
Apparently it just has random lag spikes for the first 3 days
How does a lag spike last an entire day or was it just the slow poor bt product hmmm
Expert
Looks like the same trouble I am having. I also used the Bt diagnostic test which gives speed to the hub/modem and then after the hub to the computer.
It is blaming the computer side for the bottle neck yet I have 3 different computers with different operating systems and NONE of them have any speed.
I have by passed the hub and connected to the modem, exactly the same problems yet again I know my computers are working correctly.
Sickening though isn't it that no one accepts there are problems yet again.
same here, slightly faster than what I am getting atm, download should be about 9-10x faster
Distinguished Guru
Any chance instead of whining you could do as Rayant has asked and run the tests and post the results back?
If you want help and advice the least you can do is hel;p us to help you.
Moderator
Hi Guys,
If you’re having problems with your connection speed please post the test results as mentioned by ryant704. I’m sure we can help with any issue you might have.
Cheers
David
Community ModeratorDavidM
Show your appreciation!
Kudos”
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
Expert
mine are posted under 'mods'.
Here is it right now:
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download Speed
 8.98 Mbps
0 Mbps52.56 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 8.98 Mbps
 For your connection, the acceptable range of speedsis 16 Mbps-52.56 Mbps .
 Additional Information:
 IP Profile for your line is - 52.56 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 6.38 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 6.38Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
The test result has indicated that you should contact your ISP for further assistance.
test done 08/03/2013 10:06
Download 6.46
Upload 9.05
Ping 26.38
further test
Test error
