Do you mean
BT Infinity In My Area ?
Hi So I Was Lookin On The Net And I Read Bt Infinty Will Be Ready For My Exchange Autum 2012 . The Exchange Is Bannockburn ,Stirlingshire .My Question Is Will Fallin Be Included Or Will It Just Be Bannockburn Area As Fallins Nearest Exchange Is Bannockburn But Its 2000+ Meters Away .Thanks If You Can Help
Expert
Re: BT Infinity In My Area ?
[ Edited ]
It depends on the cabinet your connected to, until the cabinet at the end of your road is upgraded then you wont be able to have it. Find your cabinet and if it has acquired a larger friend recently then you can look forward to infinity
Well actually it probably wont be there yet if the exchange is not live to autumn but look out for it
PC
Recognised Expert
[ Edited ]
This Openreach document is updated regularly every month I think... http://www.openreach-communications.co.uk/superfast/where-and-when/
It'll keep you informed of the exchange status..... then as seab20 mentioned it's a matter of keeping an eye on your small green pcp cabinet to see if a newer style of fibre cabinet with cooling vents appears nearby.
Also entering your telephone number in this checker https://www.btwholesale.com/includes/adsl/main.html
Please Click On any Text in Blue as that automatically links to information.
PC (NDEGR)
thanks guys theres only a small green box there just now But Hopfully See A Large One Soon Smiley Happy
Strange capitalisation there...
