Do you mean
Accepted Solution
BT Infinity option 2 to option 1 (unlimited)
I have been on option 2 Infinity for nearly a year but due to BT Sports I thought I would sign up for a new contract.
I have had slowish speeds on Infinity 2 since installation (30 mgps) and have had numerous engineer visits.  My sync speeds were initially high (68 i think) but have now been dropped to about 58 mgps.  I've now given up on a solution (quite some time ago).
As I havent been getting anywhere near these speeds I thought I would drop down to the option 1 - option 1 has been quoted as 40 MGPS.  This saves £3 pm.
Can anyone tell me (and apologies if this is a daft question) but would my download speeds remain the same as the most I was getting from option 2 was about 30mgps or would the change to option 1 now mean I would get less than I was before (based on the fact I was only getting about half of the download speed I should have been getting).
Hope this makes sense,
Thanks.
Expert
Re: BT Infinity option 2 to option 1 (unlimited)
I believe you would see no change. Dropping to Infinity 1 would just put a cap in to stop your speed going over 38. But I'm sure someone will correct that if I'm wrong.
Many thanks for the reply.  You were correct - in fact my overall speed actually increased!  I was usually getting about 30Mgps on option 2 - with the "downgrade" to option 1 unlimited I am now getting 35mgps!  This is obviously capped at 40mgps.
No - it doesnt make sense to me either!
Thanks again.
Distinguished Guru
Perhaps your IP profile was reset due to the downgrade?
If not, I'll try again Smiley Happy
perhaps but they tried resetting my ip profile (as well as many other things) while I was on the option 2.  Either way I'm just pleased that the downgrade actually increased my speed.  I've given up trying to find out why I couldnt get close to the expected speed on option 2
Distinguished Guru
You can't just get it reset, there has to be some activity such as a line fault being fixed, or a package change.
Newbie
Had the same issue more or less. Opted for up to ? 76mbs. Initially was 46mbs. After a couple of months from installation, the speed dropped down to 16mbs. Had quite a few calls to customer services, who were very helpful and pleasant. Loads of line checks using ethernet cable, new faceplate on my line-in box, still no improvement. Had another engineer visit, more line checks, no problems. However, we live at the limit of the Hayes exchange. Changed to Infinity 1 unlimited and Hey-Presto! Consistent 34-36mbs since then. Even saving us a few quid each month. Unless we move house closer to the exchange, we cannot get any faster speeds, but 36mbs seems to good enough for all our needs.
