Do you mean
0
BT Speedtest site
Hi,
I know to take speedtests with a pinch of salt but I was wondering about peoples experience with the BT test site http://speedtester.bt.com/.
My profile is currently set to 38Mb d/l and 10Mb u/l and if I use speedtest.net or other test sites it typically shows around 33-35 d/l (pretty good) and 3-5 u/l (not so good). However the BT site typically shows d/l speeds of 4Mb-16Mb (never higher) and up to 8Mb u/l.
Which is most representative and/or accurate?
Distinguished Guru
0
Re: BT Speedtest site
It depends on what you mean by "accurate".  BT's tester shows the speed you are getting on your line, over BT's network.  It takes no account of the connection to the Internet.
The other speed testers run over the internet, so are more realistic of real-world conditions, but don't really tell you if a problem is your line, or the internet connection as a whole.
0
Thanks,
That makes sense.
0
BT openreach engineer's prefer using speedtest.net..if thats any help...you can also try www.pingtest.net
Q. There is smoke coming out of my open reach box... so can I have a new one.
A. Sorry sir, The fault is showing at the exchange so your box should be ok.
BRING BACK UK CALL CENTRES!!!!!
