Do you mean
0
BT Wholesale Beta Speed tester
The new BT Wholesale beta tester now measures ping and upload speeds as well as the download
0
Re: BT Wholesale Beta Speed tester
So it does Smiley Happy
ALthough it has me down as a ping between 80 and 180 Smiley Frustrated
Expert
0
This is a good one http://www.vmspeed.com/
0
Is the BETA TESTER accurate?
0
I have no idea as to its accuracy
0
Download speed (for me) apprears about right (and more accurate that BT Speedtest) the upload appears (for me) a tad slow and ping is way off the scale (for me)
0
I would agree my tests would be similar to your conclusions JonP73
Expert
0
Not sure how accurate this speed test is but here's my result.
Ping 0.00Ms thinks that something may be amiss.
iechyd da
Expert
0
[ Edited ]
http://www.speedtester.bt.com/beta/speedtest-remote.jsp
Download speeds appear to be accurate for me (70.2Mbps on a profile of 72.03). Upload speeds are currently slightly on the low side (15.3, should be about 16.5) and pings are very much too high (60ms, should be 9-12 ms).  They are slowly getting there, veeeerrry slowwwwwwly!
Speedtest.net Manchester server is overall still more accurate for me though, than the upgraded BT beta speedtester. The speedtest.net ping is confirmed by bbc.co.uk (12ms).
Some of the other speedtest.net servers are rubbish though so beware, speedtesters who get poor results may be on one of them and should try half a dozen other nearby ones too.
