Do you mean
BT Wholesale speed test
Just a quick question regarding the above, I have found that if I repeat the test immediatly after running it the first time I get a noticeably higher download speed.
Is there a reason for this? Which speed reading should I work off? the first (lower) reading, or the second (higher) reading?
Re: BT Wholesale speed test
The latter,
the speed decrease could be caused by say your Java/Flash plugins. the latter would still be an accurate result.
That said, remember that the BT Speedtester is inside the WAN, for a more true internet speed, you may also want to try sites likes speedtest.net or thinkbroadband.com
Pre-warning though, expect slower speeds! Smiley Happy
In the past I have seen AV/Security software interfering with speed tests. What's the difference in speed between the two tests?
Just done two tests back to back :-
1)      D/L  50.02
         U/L    7.77
         Ping   36.00
2)     D/L  75.32
        U/L    8.05
        Ping  22.88
What do you think?
Do you have any security software running?
Do the tests at bbmax and speedtest.net also differ?
