Do you mean
0
Bit Torrent Blocked
I have been having issues the same as everyone else on here by the looks of things, but my line has settled down
to about 22mb/s (even though it was running at 37.5mb/s until they had to come and replace my modem because I had no broadband for 10 days!) and this is acceptable.
However, I am unable to get any torrents working what so ever! Not matter what the source and how many seeds there are it never starts a download. I have tried different Linux distros but none even start. This has only happened in the last week, and previously I was able to download fine with BT.
Is there a problem or am I missing something?
Thanks in advance
Expert
0
Re: Bit Torrent Blocked
Hello,
If you are after GNU/Linux distros, then use the excellent (University of Kent, UK hosted)
http://mirrorservice.org
They provide blazingly fast HTTP and FTP mirrors or all your favourite distros. On Infinity, HTTP and FTP are not traffic shaped to anything like the same degree as P2P.
It amazing the number of people who come on the forums complaining that they only use P2P for downloading distros. It's a bit like saying you only read men's leisure magazines for the articles on dragsters ;-)
Guru
0
[ Edited ]
tommybobbins wrote:
Hello,
Got to agree, anyone Linux orientated would know about HTTP and FTP downloads!Smiley Wink
0
Of course I know about the http and ftp downloads, and yes I go it from the University of Kent a few weeks ago. What I am trying to say is that I went for a torrent that should be fairly well seeded so that I could cancel out the problem of the torrent not being widely available.
Further reading has suggested that changing the port forwarding may cause issues on the HH3? Anyone like to comment on this as I have tried to make sure the BitTorrent port is forwarded to my Readynas Duo but the HH3 says there is something already listening on that port when there certainly isn't!
Guru
0
Thanks in advance
You must be missing something:
No problem here with Torrents, apart from the usual peak throttling. That does not worry me tooo much, because I get most of what I want from usenet
toekneem
(EASBF)
0
I think that the problem may now be due to the HH3? Any ideas on how to check if BitTorrent traffic is getting out?
Guru
0
[ Edited ]
I have utorrent set up with upnp and the HH3 is set up for upnp on this page:
http://192.168.1.254/index.cgi?active_page_str=page_settings_a_upnp
edit: and nothing set up in port forwarding
toekneem
(EASBF)
0
I'm not sure if that's the problem. It stopped working, so I 'messed' around with the port forwarding but what I have read is that once some ports are set they can not be cleared. Anyone else hear of this?
Guru
0
If your fiddling around has caused problems a pinhole reset would put the HH3 back to default settings as with any router.
0
Maybe what you read was this: http://www.jarviser.co.uk/jarviser/firmwarenotes.html
There is a solution there aswell. It might not apply to the Hub v3. I'd hope not anyway since it's a bug relating to forwarding ports and bt are now charging for assistance relating to forwarding ports!
