Do you mean
Connect to BT Home Hub 3 via external ip address
I have a NAS device that I have been backing up my websites too.
I am unable now to connect to them - error message:
"Unable to connect to FTP address `xxx.xxx.x.xxx` on port `21`."
This has been working - now, suddenly, is not.  I have port forwarding setup correctly for ftp.
Any suggestions, please?
Mike
Guru
Re: Connect to BT Home Hub 3 via external ip address
Try re-assigning the device in the hub, mine does it from time to time as disconnect my adapter it resets the mac code. Then the hub will have it under a different mac ID...
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
Thanks for that - yep tried that already - no change.
Cheers,
Mike
Expert
Has your external IP address changed?
You should use a DynDNS type service to connect to a CNAME rather than IP.
Nope.
Guru
Try ftp://192.168.1.253/
not relevant
Expert
Does shields up show the port as open?
http://www.grc.com/intro.htm
Followed an earlier suggestion - setup a free dydns from http://www.no-ip.com/.  Entered the relevant details in the BT Home Hub 3 dydns settings.  Connection from all of my sites now working as they should.
There is a utility that can be run that schedules checks on the ip address - I suspect this is not required if the dydns details are directly entered on the hub.
Cheers.
Expert
[ Edited ]
I'm guessing your external IP had in fact changed.
It can sometimes do this daily so I would set it to update from the hub and not bother with the utility.
One thing to bear in mind with a free no-ip is that you have to log into the account at least once a month.
