Do you mean
0
Do I have to use the BT Homehub 3 with BT Infinity?
Is it possible to use a different router with BT Infinity? I am seeing some issues which I want to test with an alternative router.
Thanks Much!
Distinguished Expert
0
Re: Do I have to use the BT Homehub 3 with BT Infinity?
yes it just needs to have a wan port and be able to do pppoe
0
No, there are some alternatives here.
Replacements for BT home hub 3
Guru
0
If you just want to test to check out what the issues might be, you can plug a standard PC directly into the modem and do a pppoe connection from the PC.
0
Thanks for all the feedback. It'll be a while before I can check.. but I will post the results when I can.
