Do you mean
0
Re: FAO Aarong/Webby - BT NetProtect Plus Firewall is causing my erratic speeds?!
Aarong wrote:
Sweeeeeet! going to see that tomorrow Smiley Very Happy and yea your right, whilst i have issues with Kaspersky on my P.C, hardly affects my iMac at all!
Thats good to know. My iMac is wired so that should help things along. I'm not upgrading but going right in at the deepend. Crossing my fingers my install goes ok.
Distinguished Guru
0
Try an alternate like google chrome.
i had the same problem with Bt netprotect,i soon uninstall that now i use AVG free,no problems now.
