Do you mean
PC
Recognised Expert
FTTC Exchange and Cabinet BT Wholesale.
This is interesting....
In the Post Code to Cabinet (PCP) Mapping, you can identify the Cabinet number for your Post Code, and get the percentage of lines in that cabinet that are going to be upgraded to fibre. (I have noticed 100% to as low as 9.37%).
You may have to go to the 4th column D and expand it sideways to reveal the cabinet number.
Initially mine showed only the exchange NDEGR and I expanded it to reveal P32, which is the correct cabinet that I am connected to.
Please Click On any Text in Blue as that automatically links to information.
PC (NDEGR)
Moderator-Retired
Re: FTTC Exchange and Cabinet BT Wholesale.
[ Edited ]
Nice find PC - good to see BT Wholesale have made this information public again. It should help a lot of people out Smiley Happy
edit* it seems that they've pulled this from public view again. I've posted a general availability FAQ which may help most people, but if anyone is at a complete loss and would like cabinet information we're still able to see this so feel free to contact me via the usual method Smiley Wink
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
Distinguished Guru
Good job I downloaded it before it was pulled.Smiley Very Happy
PC
Recognised Expert
[ Edited ]
This still works....
PC (NDEGR)
Distinguished Guru
You downlaoded it as well!Smiley Wink
Can someone please explain to me how to read this - as far as I can tell from this I should be able to get Infinity - the BT checker says I can't?
SAU_ID Name Postcode SAU_NODE_ID Exchange Only Flag Percent Lines Uplift Phase Deployed FTTC or FTTP
NIMR MOIRA BT67XXX {NIMR}{p14} 0 100 25.16 NI 6a YES FTTC
What does phase 6a or 4a stand for???
Mul
Just had a look at the .csv at the above drop box link.
FTTC/P seems to be coing to most neighbouring streets under "Phase 7b" however my postcode is not listed. Does anyone know how I could go about finding out the exact reason why my post code isn't going to be part of the roll out? Would love to get to the bottom of this as sub 1.5mbps broadband within <2 miles of the heart of London is a disgrace.
some reason when i open this file it says "not all the file is loaded" any help please
Distinguished Guru
I got the same error, although the spreadsheet only seemed to include from exchange Aberkenfig to Belfast so quite a lot missing from the rest of the exchange areas
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
