Do you mean
Newbie
How do I change my IP address without restarting my HUB
Hello,
basicly what the title says I wish to change my IP, but I don't want to go through the hastle of turning off then on my router.
I'm running BT infinity 1
Recognised Expert
Re: How do I change my IP address without restarting my HUB
If you go into the homehub settings and disconnect then reconnect apparantly this gives you a new ip addy.
