Do you mean
Huawei EchoLife HG612
Does anybody know if you can buy this box, or is it made for Openreach.
Expert
Re: Huawei EchoLife HG612
Hi there,
I'm pretty much certain that the OpenReach modem isn't available for purchase by customers, sorry.
I hope this info helps. Smiley Very Happy
[ Edited ]
Rottie wrote:
Hi there,
Thanks for the quick reply. Then I will get this VDSL device http://www.dabs.com/products/billion-wireless--n--firewall-vdsl2-router-7RKP.html?src=15, "Billion Wireless 'N' Firewall VDSL2 Router", as a replacement for my Infinity. Thanks Robin
Distinguished Expert
plenty on a well known auction site
Yep, though ideally you should be trying to get the latest version which has a white power lead. Earlier versions were prone to overheating.
and the letters 3b on the label on the bottom
Newbie
Mines a model 3B. Reading various posts, can someone please clarify:
1. Is model 3B a later version than 2V?
2.Should I mount it on a vertical wall? Seems like easy enough to do so. There are mounting slots on the bottom, and screws/plugs in the package.
I havent had any problems whatsoever, but am keen to do the right thing to avoid any future problems when global warming causes temperature/sea levels to rise.
Distinguished Guru
[ Edited ]
3B is the latest model HG612
You can mount it on the wall
I have my modem standing on its edge
Forget Global Warming it stopped 10 years ago
If not, I'll try again Smiley Happy
