Do you mean
0
Speed test most accurate.
Hi
How can you get an accurate test on the speed for Infinity.?
(Im on wireless so know its not going to be top notch)
BUT
BT speedtester said I have 0 Mbps
Speedtester.net gives 10 Mbps
Speedtester max give 25 Mbps.
How can I tell if im getting what Im paying for?
HKA
Distinguished Guru
0
Re: Speed test most accurate.
Does the service work for what you want to do? Streaming, browsing, youtube etc?
For me that's what I pay for, and so long as it works, I don't care what number is reported by any given test site.
Expert
0
hongkongandy wrote:
Hi
BUT
HKA
Hi there,
For me, I find that the most accurate speedtester is Virgin Media Speedtest
I hope this info helps. Smiley Very Happy
0
Hi Webby, good point. Yes it works but if Im paying for infinity I would like to think I getting infinity speeds and not Total Broadband..
Distinguished Guru
0
My point is buddy if it's working then that is what you're paying for?
Whether there's 5 meg or 25meg sat there "wasted" you shouldn't worry about it Smiley Happy
