Do you mean
Accepted Solution
Speedtester.bt.com
Hi,
Just wondering if anyone else is having problems with the speedtester.bt site.
My IP profile has dropped in the last couple of months from 76 down to 62 and now when I check on it, on the speedtester.bt site, it freezes on the upstream test when it riches 100%. Then comes up An Error Has Occurred. Just wondering if anyone has had a similar issue or knows what the problem is.
Re: Speedtester.bt.com
Use http://speedtest.btwholesale.com/ instead ... and then go to the fufther diagnostics to get your IP Profile.
I think it uses the Beta engine, so will likely over-estimate your speed.
For a realistic idea of what your connnection can actually do try this ...
http://mcslhr.visualware.com/myspeed/myspeed_line_capspeed.html
Rob
Thanks for that.
