Do you mean
Street Cabinet
Hi
My exhange is due to be enabled in September this year, Exchange is Widnes (LVWID) Ive seen a few streets in the area with the new Fiber cabinets installed as well.
Im on CAB P82 and the Postcode is WA8 8UE, However according to the December 2011 Spreadsheet it says that my Cabinet is 'Not part of a phase' Does this mean that BTO have not set a date to upgrade it yet, or i cant get infinity at all?
Estate is a modern build about 5 years old, can anyone tell me somehow if my Cab will be upgraded in due time? BT wholesale checker says not available yet which is obvious.
Recognised Expert
Re: Street Cabinet
As I understand it the exchange gets upgraded then there is a roll out to the multitude of cabinets.
The easiest way to check is to try this link  http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=29017&s_cid=con_FURL_...   and enter your details.
Alternatively this may help https://www.btwholesale.com/includes/adsl/main.html  ( you may need to show all content)
Re: Street Cabinet
It means at this time there are no current plans to upgrade the cabinet however it could be upgraded in a future phase
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Re: Street Cabinet
Hi, i had an idea thats what it might be.
Re: Street Cabinet
Hi forgot to add, how would Openreach determine were i live is Commercially Viable? Would this already be done now, or only when they - for example begin a new phase etc? I know its a confusing question, just trying to cover as much as possible.
Re: Street Cabinet
most likely already decided if your exchange area already has fibre then the viability study will have already been done
Also remember the 2011 spreadsheet is now well out of date not every cabinet is upgraded first time around
Try a Search
