Do you mean
Newbie
Accepted Solution
TAP 3 Test and Windows 7 Help
Can someone help me, I'm new to this and have been getting horrendous speed results. Speedtester asks me to complete the tap3 test but I can't find where to change my username to complete this test. I have copied some results into a Word document but can't seem to paste them here maybe someone could help me on that one as well. By the way I am in Coleraine.
Re: TAP 3 Test and Windows 7 Help
You need to change it in the home hub.
Go to 192.168.1.254 and log in.
Got to the advanced settings tab and then internet.
Press disconnect, change the username, and then click connect.
Once you've ran the test, carry out the same process but put the original username back in.
Newbie
thanks for your speedy and knowledgeable answer I will be able to do the tap3 test when the hours up, again thanks
