Do you mean
Twitch.tv - Constant Buffering and concerning tracert
Hey,
I was wondering if I could get some help with a constant buffering issue with twitch.tv
I have the 80/20mb package and I am on totally unlimited however when ever I try and use twitch.tv I get constant buffering no matter what resolution.
I have ran a tracert and I am surprised to see a number of request time outs which would suggest its a problem with BT rather than at my end.
I have copied the tracert below and would appreciate some quick assistance on this matter.
tracert www.twitch.tv
Tracing route to cdn.justin.tv.c.footprint.net [4.26.227.126]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  BTHomeHub.home [192.168.1.254]
  2     5 ms     5 ms     5 ms  217.32.146.171
  3     5 ms     5 ms     7 ms  217.32.146.238
  4     6 ms     5 ms     5 ms  213.120.156.146
  5     6 ms     6 ms     6 ms  217.41.168.213
  6     6 ms     6 ms     7 ms  217.41.168.109
  7     6 ms     6 ms     6 ms  acc2-10GigE-0-0-0-4.l-far.21cn-ipp.bt.net [109.1
59.249.194]
  8    10 ms     7 ms     7 ms  core1-te0-7-0-16.faraday.ukcore.bt.net [109.159.
249.137]
  9    11 ms    10 ms    11 ms  62.172.103.9
 10     6 ms     6 ms     6 ms  transit2-xe-3-0-0.ilford.ukcore.bt.net [62.172.1
03.161]
 11     7 ms     7 ms     6 ms  t2c4-xe-10-0-0.uk-ilf.eu.bt.net [166.49.168.97]
 12     7 ms     6 ms     7 ms  xe-10-3-1.edge3.London1.Level3.net [195.50.124.2
1]
 13     7 ms     7 ms     7 ms  vl-3502-ve-116.csw1.London1.Level3.net [4.69.166
.133]
 14     7 ms     7 ms     8 ms  ae-56-111.ebr1.London1.Level3.net [4.69.153.113]
 15     7 ms     7 ms     7 ms  ae-1-3.edge4.London2.Level3.net [4.69.141.190]
 16     *        *        *     Request timed out.
 17     *        *        *     Request timed out.
 18     *        *        *     Request timed out.
 19     *        *        *     Request timed out.
 20     *        *        *     Request timed out.
 21     *        *        *     Request timed out.
 22     *        *        *     Request timed out.
 23     *        *        *     Request timed out.
 24     *        *        *     Request timed out.
 25     *        *        *     Request timed out.
 26     *        *        *     Request timed out.
 27     *        *        *     Request timed out.
 28     *        *        *     Request timed out.
 29     *        *        *     Request timed out.
 30     *        *        *     Request timed out.
Re: Twitch.tv - Constant Buffering and concerning tracert
I watch twitch and I think it's at their end. Sometimes it goes fine and sometimes it is awful. I've found the worse time is when it is afternoon/early evening in the US.
many servers do not respond to being pinged it does not mean there is a problem
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
the 720p mlg stream has started buffering for me in the last half hour, if it doesnt improve i'll try the 480p stream,
no idea if its a bt or twitch issue, anyone with another isp able to comment on their stream experience?
 i think it may be a twitch issue as the same thing happened during the cod championships
For basic tasks a non direct route is not an issue. However for streaming sites this is and issue.
I don't think the problem is at twitch.tv ends as it works perfectly on other ISP's. Their has also been a recent case in NA in regards to the same issues shown by the same sort of tracerts that was happening on the timewarner ISP.
The problem turned out to be timewarner not wanting to fully support the site but after high level talks late last week they did support and all issues dissapeared.
I would suspect this is a similar issue.
I would be interested to hear an offical response from BT.
This is a customer to customer self help forum posts made here do not directly to BT the forum is moderated by BT employees (part of BTcare) but not all posts are read by them so you are unlikely to get an official response
Try a Search
So where do we get offical support then?
Distinguished Guru
https://bt.custhelp.com/app/contact
If not, I'll try again Smiley Happy
or here I suggest you contact the forum mods they should be able to get this problem sorted for you this is a link to them http://bt.custhelp.com/app/contact_email/c/4951
They normally reply by email or phone directly to you normally within 3 working days they will take personal ownership of your problem until resolved and will keep you informed of progress
They are a UK based BT specialist team who have a good record at getting problems solved
This is a customer to customer self help forum the only BT presence here are the forum moderators
Try a Search
