Do you mean
Using Home Hub 3 on another ISP
Hi
Does anyone know if the home hub 3 can be used with another ethernet connection
Specifically ,I am away on business next week and the hotel has ethernet ports [DHCP]
Can I plug the HH3 into here ?
I know I can use a buffalo cable router in this scenario but will the HH3 work ?
Re: Using Home Hub 3 on another ISP
the HH3 is locked to bt and your unique phone number is part of the authentication
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
Guru
[ Edited ]
And they haven't found a way of unlocking it yet.
toekneem
(EASBF)
I know that but that but you are not allowed to comment on hacking the HH in the BT forum.
can't understand need for router when the ethernet cable will connect to presumably the laptop
Distinguished Guru
I can confirm that if you do, it's a rollocking and removal of the post(s)
-+-No longer a forum member-+-
thanks DS
but it is alright to take them apart Smiley Wink
Distinguished Guru
Of course it isSmiley Wink
I guess even adding bits to the HH3 is possibleSmiley Indifferent
(now where did that post go....?)
