Do you mean
Web access to router
Hi,
New to the forum, so apologise if I've posted in the wrong forum or done anything else that is amiss.
Can I find the IP address for my router so that I can connect to it in a web browser?  I'm just intruiged to see it's stats.
Many thanks,
Dave
Distinguished Expert
Re: Web access to router
Which router?
If you're using the home hub it's 192.168.1.254
I'm using the Huewai one.  The problem is that I'm using a slightly different subnet so that I can access my work network using my VPN connection.
The DHCP IP range that I'm using is 172.16.0.64 - 172.16.255.254.
Allocate an IP to your PC in the same subnet as the router. say 192.168.1.10, then plug a cable between your PC and router into LAN2 under the tape, and browse to 192.168.1.1
Recognised Expert
bludigi,
When you state "router" do you mean the HH3.?
The OR "Modem" is the white box and you can`t get any stats info from it.
The "modem" is a router
Hi,
Sorry I meant modem!
Was just interested to get some line stats.
bludigi wrote:
Hi,
I don't think you can.
Recognised Expert
Bullitt,
The Modem is not a router,it is a Modulator/DeModulator that modulates the incoming VDSL signal data and then demodulates it into data that is then passed to the HH3 [or other] router.
The Router is just an auto switch that sends data to your network PCs via ethernet ports.
