Do you mean
Where is my Cabinet situated
Can anyone tell me where my telephone Cabinet is my post code is CH7 1UG Thanks
Guru
Re: Where is my Cabinet situated
Hi, unfortunately no one can tell you where your cabinet is, but i can tell you that you are on cabinet number 19.
After that it's a good old fashion look around or possibly or google maps, it should be numbered on the side or on top.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
