Do you mean
Wholesale Speed Test
Occassionally I get this when clicking on the "Run Diagnostic Test" button.
What does it mean?
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
java.lang.IllegalStateException: Cannot forward after response has been committed
	org.apache.struts.action.RequestProcessor.doForward(RequestProcessor.java:1078)
	org.apache.struts.action.RequestProcessor.processForwardConfig(RequestProcessor.java:396)
	org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:232)
	org.apache.struts.action.ActionServlet.process(ActionServlet.java:1913)
	org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:462)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
note The full stack trace of the root cause is available in the Apache Tomcat/6.0.16 logs.
Distinguished Guru
Re: Wholesale Speed Test
It means what it says in the description. Their server-side java process has thrown an error.
If not, I'll try again Smiley Happy
Well ray_dorset, I can read Smiley Wink
Why?
Is it all to do with BT's server or has it anything to do wth the speed test interaction with the HH3?
All the best
Distinguished Guru
It is all to do with BT's server.
Expert
I think that they have fixed it this morning. I just tried doing one and it worked ok. This issue with their servers has been going on randomly for 5 years to my knowledge. I do wish they would fix it.
Infinidim
Megadodo Publications
Ursa Minor Beta
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side
If the the reply answers your question then please mark as ’Mark as Accepted Solution’
