chrismuk
Newbie
Message 1 of 3
4G compatability
I have a OnePlus One phone which is not compatable with 4G band 20. It has bands 3,4,7 and 17 though. What band /s does BT 4G use and will my phone work with BT mobile 4G if it ever extends to my area?
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: 4G compatability
Hi chrismuk,
Welcome and thanks for posting. BT Mobile should be able to support Band 3 and 7 so we don’t see any issues using your OnePlus One handset.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
Deathtrap3000
Recognised Expert
Message 3 of 3
Currently using my oneplus one with BT and get 30mbps over lte with no issues.
