Amberley
Message 1 of 10
4g not working on social mediA
My 4g works fine for the web but I can’t load any social media apps, it isn’t says no connection. This has happened with all my phones and I am currently using an iPhone 7
How do I solve this?
9 REPLIES 9
NeilO
Moderator
Moderator
Message 2 of 10
Re: 4g not working on social mediA
Hi @Amberley, welcome to the community and thanks for posting. I've moved your post to the Mobile section of the community as this is the best place to get help. I'd recommend checking that there are no parental controls set up as these may be blocking social media apps when on 4g. Log in to www.bt.com/mymobile with your BT ID to check the Parental Controls settings.
Amberley
Message 3 of 10
Ah thank you! Where abouts in the BT app is the parental controls?
Matt-S
Moderator-Retired
Message 4 of 10
@Amberley
You can access Parental Controls by logging into MyBT on BT.com and going to the My Extra's section.
Let me know if you need any more help 🙂
Matt
Amberley
Message 5 of 10
The parents controls are switched off. My brother has the same bt package/sim and is able to use his social media, as can my dad and mum. It’s just me who can’t
JohnC2
Moderator
Moderator
Message 6 of 10
Hi @Amberley thanks for the update. I'm not sure that the Parental Controls in the extras section relates to the Mobile. I've found this article on BT Mobile Content control and settings that has step by step how to check the settings on your phone.
Check it out and hopefully it helps
cheers
John
karatechameleon
Message 7 of 10
Hi I’ve got the same problem and I was looking for a fix, just wondered if you could send me the link.
thanks
chris
CJT80
Recognised Expert
Message 8 of 10
@Amberley
You should be able to find out more info here
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
karatechameleon
Message 9 of 10
That just redirected me to parental controls which isn’t the problem for me.
Any other advice?
ctrlz
Message 10 of 10
Once you've logged in, go to 'Your Products - Manage', then to 'Mobile - Manage', then highlight the number in question (if you have more than one), scroll down and you will see your parental controls along with spend cap settings.
