Don49
Newbie
Message 1 of 3
5G
As a BT Plus customer I have been offered an upgrade to 5G will this over come my home mobile signal as at present I do not receive any signal strength for calls in or out
2 REPLIES 2
-Richie-
Expert
Message 2 of 3
Re: 5G
BT Plus customers get 5G access first, you would need a device that supports 5G and have 5G in your area, It's currently limited but it is being deployed so coverage will improve.
Where 5G isn't available you'd revert to 4G, where no 4G is available then you'd connect to 3G.
Moderator
Moderator
Message 3 of 3
Re: 5G
@Don49 BT don't have a coverage checker yet but as BT mobile works on the EE network you could enter your postcode on their coverage checker to see if 5G is in your area.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
