XxSteveDxX
Message 1 of 7
Activating BT sport after sim only deal purchased
Hi, I have bought a 6gb BT mobile sim and wanted to know how u go about getting the free BT sport working that comes with it please?
6 REPLIES 6
Dean007
Recognised Expert
Message 2 of 7
Re: Activating BT sport after sim only deal purchased
Hi @XxSteveDxX
Have you downloaded the BT Sports App?
BT Sports App
XxSteveDxX
Message 3 of 7
Yes I have Dean
Dean007
Recognised Expert
Message 4 of 7
@XxSteveDxX
If you log into your BT account, and try add BT sport as an item does it let you select it to add to the account? It should say free next to it.. It should give options about where you want to watch it? If it wasnt pre-selected when purchasing the sim..
XxSteveDxX
Message 5 of 7
Hi, it says monthly £0.00 then under that says free for 3 months then £7 from month 4.
I thought it was free for the duration of my bt mobile contract?
NeilO
Moderator
Moderator
Message 6 of 7
@XxSteveDxX if you need any help getting your BT Sport app activated send over your details on the 'click here to contact the mods' link in my forum profile. You can find the link by clicking on my username.
XxSteveDxX
Message 7 of 7
Hi Neil, I've sent a request as you mentioned above.
