neil4768
Message 1 of 2
Activation Pin
Just received my sims, where are the activation pins for them, as I cannot see them in the welcome pack my order number is ***edited by Mod****
1 REPLY 1
Fusionmoth
Message 2 of 2
Re: Activation Pin
You Don't need an activation pin, just pop onto your MyBT and click "activate my sim" ... are you sure your phone is unlocked, cause maybe it's asking for a network key or something similar which has no bearing on the sim card activation?
