Peter30
Message 1 of 5
Add BT mobile
How much per month will it cost me to add mobile to my existing phone/broadband package, and can I choose sim only?
4 REPLIES 4
NeilO
Moderator
Moderator
Message 2 of 5
Re: Add BT mobile
Hi @Peter30, welcome to the community and thanks for posting, the cost of our sim only packages range from £5 to £25 and are priced depending on how much data you require and the length of contract you choose. Check out this link for more info on our Sim only deals.
Peter30
Message 3 of 5
Re: Add BT mobile
Thanks Neil0, can I shoot another one at you: what if I wanted to effectively replace my landline with a sim only plan, and keep the broadband as is;
- could this be done as a 'swap over';
- would I have to change the plan altogether;
- is line rental involved in a sim only plan?
NeilO
Moderator
Moderator
Message 4 of 5
Re: Add BT mobile
Hi @Peter30, I'm afraid that's not possible if you want to keep your broadband as is you'll still need to have a landline. The landline rental is included as part of your overall broadband package charges.
If you're looking to save some money and you aren't in a minimum term contract I'd recommend speaking with our value team on 0800 800 150 as they may be able to offer you a discount on your current package if you were to renew the contract.
Peter30
Message 5 of 5
Re: Add BT mobile
Okay, thanks Neil
