panoulix
Message 171 of 450
Re: Amazon/iTunes Voucher
Same issue here.
Both me and my partner signed up with BT mobile since the 23rd of August.
Still haven't received anything, despite my attempts to chase this for weeks with their helpdesk and chat.
Looks like it's a standard practice from BT to keep on ignoring their customers.
I will try to contact NeilO and the mods in a hope to get this finally sorted.
However failing this, the next step is Citizens Advice Bureau and Trading Standards by pointing them a link to this thread as well, as provifing other evidence I have already gathered.
gregm
Message 172 of 450
My wife and I are in the same position. I applied 2 months ago, and my wife 3 months ago. Will also try the mods.
adewolves
Message 173 of 450
Mine got sorted when I used this forum...thanks admin
Moderator
Moderator
Message 174 of 450
Hi @adewolves,
Thank you for posting back. I'm happy to hear that your voucher arrived Smiley Happy
Cheers
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
staffsbloke
Message 175 of 450
Hi
I activated my BT sim on 24 August and claimed my Amazon voucher the next day - but still no sign of it.
Can anyone tell me where the link to contact the mods about this is?
Cheers
gregm
Message 176 of 450
Wolud appeciating a mod pinging me the contact mods link so I can get to the bottom of this.
Moderator
Moderator
Message 177 of 450
@staffsbloke and @gregm I'm sorry about the delay with your vouchers. Have you contacted the voucher team on this link yet?
Community ModeratorNeilO
Kudos”Kudos”
gregm
Message 178 of 450
Hi @NeilO
Yes, filled in the form a few weeks ago but no response yet.
Have just completed it again
Moderator
Moderator
Message 179 of 450
@gregm Sorry about that, we can chase this up for you if you use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username .
Neil
Kudos”Kudos”
panoulix
Message 180 of 450
The "contact the modes" link under your username (or if I click your username) does not show up.
Even the "contact me", is also inactive.
Any thoughts?
