Message 1 of 2
Android mobile fails to connect to BT wifi on roaming.
I have 700 minutes of mobile access. I have tried to make my mobile phone connect. I go to the 'BTwifi' signal and click on 'Login' purple button and put in username and pwd but it always fails. This is very frustrating. I see there is a Gnnnnnn number mentioned somewhere to use but that is not a username just an ID. Advice appreciated. PS I have not found an app for my EE phone either on Play Store. Thanks.
1 REPLY 1
Message 2 of 2
Re: Android mobile fails to connect to BT wifi on roaming.
the sign in to BTWIFI is using your BTID and password - not any wifi login or password
