Message 1 of 4
Another BT Sim Activation Problem
New SIM only delivered yesterday for an unlocked OnePlus, followed all instructions, had text saying I was activated, tried to complete BT webpage to carry old number from Three with PAC code, page says I'm not activated ! So I wait 24hrs and try again, still says I'm not activated, (using keepmynumber), webchat advise they have now activated again but keepmynumber says I'm still not.
What a mess, I've had a text saying I'm activated but your system shows I'm not, thank goodness for the 14 day cancellation period, if this doesn't get sorted I'll be using it.
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Another BT Sim Activation Problem
Hi @saprolith,
Welcome to the community forum and thank you for posting.
If you take a look at - Can I keep my number when I move to BT Mobile?
Once you've activated your SIM and given us your PAC code, it could take up to three days to move your number.
PaddyB
Message 3 of 4
Paddy, you clearly did not read my post, please read it again and then you'll see what the problem is.
Message 4 of 4
Saprolith, if I were you I'd simply give them a ring, you don't wait for hours on hold to get through to mobile. 150 from your handset (if it is indeed activated) or 0800 800 150 . They'll be able to clear it up for you
