Message 1 of 11
BT Mobile Data Roaming not working in Portugal
Can anyone help....BT mobile data not working in Portugal. SIM recently transferred from iPhone 6 to iPhone 11. Calls are working and data worked OK in UK.  I have checked mobile data settings. Turned off mobile data and phone and back on again. Urgent as need for work.
10 REPLIES 10
Moderator-Retired
Message 2 of 11
Re: BT Mobile Data Roaming not working in Portugal
Hi @Chrisbradley80,
Welcome to the Community and thanks for taking the time to post.
Sorry to hear that data roaming is not working for you when abroad.
Can you check to see if you have a spend cap set up?
If the cap is set to zero can you change it to £5 or £10 and see if you are able to use the data then?
Let me know how you get on.
Matt
Message 3 of 11
Thanks Matt. Account is all in order and cap is £200 with zero spent
Message 4 of 11
Data Roaming not working on IPhone 11 in Portugal
Moderator-Retired
Message 5 of 11
@Chrisbradley80,
I'm out of ideas. You will need to call our mobile team so that they can check the account.
From the UK: 0800 800 150
From BT Mobile: 150
From outside the UK: +44 179 359 6931
Matt
Moderator-Retired
Message 6 of 11
@Chrisbradley80,
Have you double-checked that data roaming is switched on within the phone settings itself?
  1. Press Settings.
  2. Press Mobile Data.
  3. Press Mobile Data Options.
  4. Press the indicator next to "Data Roaming" to turn the function on or off.
  5. Slide your finger upwards starting from the bottom of the screen to return to the home screen.
Matt
Message 7 of 11
I have done this, I have changed network selections, I have re started my phone. None of this works
Message 8 of 11
@Chrisbradley80
Have you called the mobile team to make sure something is not switched off in the background?
@Matt-Swrote:
@Chrisbradley80,
From BT Mobile: 150
Matt
Message 9 of 11
I have spent 2 hours trying to reach them.  I have emailed the technical team and BT customer service.
Message 10 of 11
Matt
last time I had a problem in Dubai I spent £150 on land line calls to BT Help!  They need more focus and resource.
chris
