ria1979
Message 1 of 7
BT Mobile Direct Debit hell
I have BT mobile family with 2 sims. Been happily paying it via DD for 18 months or so.
I took another contract out recently and although I was told I can’t have it on the family plan it’s still getting billed with my family plan.
For my own records, I need to be able to pay my new bill on a separate Direct Debit. I’ve tried changing from settings but the details get applied to both contracts.
Come on BT. Can’t be hard to set up a separate Direct Debit.
6 REPLIES 6
Moderator
Moderator
Message 2 of 7
Re: BT Mobile Direct Debit hell
Hi @ria1979 Sorry you are having a problem with the set up of your Mobile billing.
Please contact the BT Mobile Chat Team and they will be able to help you with this.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
ria1979
Message 3 of 7
So, apparently I couldn’t get my new contact on my family plan but billing can’t be set up on separate direct debits. SERIOUSLY?
ria1979
Message 4 of 7
FYI spent over an hour on chat and then spoke to customer service and they said my new contract can’t be billed separately.
Fusionmoth
Message 5 of 7
Easiest way around this: get the new contract put on a separate BT account, payable by direct debit to the separate direct debit details - granted it then means you have 2 BT accounts but it's a way?
ria1979
Message 6 of 7
How do I go about doing that? Thanks
Fusionmoth
Message 7 of 7
I guess the easiest way would be to ask the live chat, otherwise if you give the mobile team a ring at least you'll get to someone in the UK
