James1618
Newbie
Message 1 of 8
BT Mobile Roaming Not Working
I'm currently in Japan on holiday and I can't get the mobile roaming to work. I received a text after we landed with the rates, and have roaming turn on in both my phone settings and my BT mobile settings but it still won't let me use data.
What else do I need to turn on or register so I can use it?
7 REPLIES 7
Message 2 of 8
Re: BT Mobile Roaming Not Working
obviously your mobile package data for roaming is not available in Japan  have you set your spend limit to zero on your mobile data?
looking at BT mobile it costs £5 per mb of data in Japan
Moderator
Moderator
Message 3 of 8
Hi @James1618 sorry about that, I've seen this happen before when there is a spend cap in place on the mobile account as data in Japan costs £5 per MB.
Can you login to MyBT and increase your spend cap to over £100 and let me know if that helps?
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
James1618
Newbie
Message 4 of 8
Both the additional charge and roaming limits were set to £20, but I'll up the additional charge one in case that makes a difference.
Do you think it's also worth cycling through the different networks to see if that makes a difference? Maybe it was an initial connectivity issue, in which case would a restart help? No harm in trying with either of those so I'll have them a try anyway.
Moderator
Moderator
Message 5 of 8
@James1618 if your spend cap is set to £20 that will stop your data working when in Japan. If you up that to £100 it should sort it. Post back and let me know if that works.
Kudos”Kudos”
Message 6 of 8
£20 won't last long at £5 per mb
James1618
Newbie
Message 7 of 8
Upped it to £100 and restarted my phone and it appears to be working. Thanks for the help!
Moderator
Moderator
Message 8 of 8
@James1618 Brilliant, I'm glad that worked 😀
Kudos”Kudos”
