Message 11 of 295
Re: Disappointing
I did look for the T&Cs, but could not find them. Not sure how they could actually check that, as its mostly down to the phone hardware.
Its always worked with the existing network, so perhaps there is something in the new SIM that stops it?
Its not really a feature I have used much as I have a mobile broadband unit with a Three SIM card in it.
I just hope they can supply a standard SIM card as my phone uses one of those.
Message 12 of 295
Re: Disappointing
I don't think you would have a problem but they may check for large spikes of data usage.  many of the providers say tethering is not permitted but don't actually stop it
the BT sim comes standard size with the smaller sim built in so if you need smaller sim for newer phone you just 'push it out'
gomezz
Recognised Expert
Message 13 of 295
Re: BT Mobile SIM only plans - Tethering?
As I have a Windows mobile phone I have to run the BT Sport app on my Android tablet which is preferable anyway with its larger screen. Sometimes cannot find an Openzone wi-fi hotspot for the tablet to connect to but get a decent mobile connection so can turn on Internet Sharing on the mobile phone and connect the tablet to that. As that uses exactly the same amount of data to use the BT Sport app I do not see why BT should not support it.
deathaxe
Expert
Message 14 of 295
Re: Disappointing
Same here complete deal breaker as I have not only used wireless tethering when going out but wired tethering when there was a big fault at the exchange and I didn' have broadband for several days.
Also the 20 gig package is very large, I haven't ever got near that even with Netflix etc.
Oh well will stick with 3 for now.
deathaxe
Expert
Message 15 of 295
What is hilarious is that EE allows tethering yet they have tiny data plans, yet BT with much larger data plans won't.
Also tethering can be blocked by the network so it may not be as simple as "not supported" as in fully blocked.
Oh well will currently stick with 3 with their unlimited data and tethering plan which I got 3 years ago.
Just hope the merger with O2 don't, muck that up.
Message 16 of 295
Re: Disappointing
I can't understand why you would stop customers tethering on packages that have data limits - does it matter whether I use my data limit on my phone or when my phone is tethered to my laptop.  If I go over my monthly data limit then I will be charged whether I have used tethering or not
I can understand that you are not permitted to tether if the package had unlimited data
high_peak
Newbie
Message 17 of 295
Deal breaker for me too - Thank for this thread - just about to order BT fibre unlimited with sim only broadband - and would like the 20gb plan - just as a backup, should fibre ever fail - I only use about 1gb tehtered - but the backup of tethering is reassuring - will tethering be allowed once the full changeover to EE is complete? - another poster siad it might be - until then I will stay where I am - all out of contrcat on mobile and phone and fibre - will wait and see - not moving to BT without tethering.  Thanks for the posted information - very helpful
Tags (1)
Message 18 of 295
lee
Message 19 of 295
Re: Disappointing
The other issue is that sometimes they control what options you have via a carrier update.
For example I'm on O2 payg and O2 have removed the 'Personal Hotspot' toggle from my iPhone as tethering is only permitted for contract customers.
Tethering causes strain on the network as it allows the viewing of richer content on a laptop etc which in turn is why a data allowance is used faster.
hippey
Expert
Message 20 of 295
Re: Disappointing
The hotspot option does not appear on the iPhone 5 with BT Mobile. Can't comment on other devices but certainly doesn't allow tethering on one of our phones.
